create vman
create vman [vman-name | vman_list] {learning-domain} {vr vr_name}
Description
Creates a VMAN.
Syntax Description
vman-name Specifies a VMAN name using up to 32 characters.
vman_list Specifies the VMAN tag range or VMAN Tag List (Ex: 2-4 or 2,3).
learning-domain Specifies that this VMAN is a learning domain, which supports inter-VMAN forwarding.
vr Specifies a virtual router.
vr_name Specifies a virtual router name.
Note: User-created VRs are supported only on the platforms listed for this feature in the Switch Engine v33.1.1 Licensing Guide document. On switches that do not support user-created VRs, all VLANs are created in VR-Default and cannot be moved.
Default
N/A.
Usage Guidelines
For information on VMAN name requirements and a list of reserved keywords, see Object Names. You must use mutually exclusive names for:
The keyword learning-domain enables you to create a VMAN that serves as a learning domain for inter-VMAN forwarding.
If you do not specify the virtual router, the VMAN is created in the current virtual router. After you create the VMAN, you must configure the VMAN tag and add the ports that you want.
The following example creates a VMAN named "fred":
create vman fred
This command was first available in ExtremeXOS 11.0.
The vman_list variable was added in ExtremeXOS 16.1.
Platform Availability
